HM_DONOT_READ_SETTING_FILES
Determines the action taken if HyperWorks crashes during invoke.
HM_DONOT_READ_SETTING_FILES mode
HyperMesh Environment Variable
Any invoke after a crash automatically bundles setting files like hmmenu.set, hmsettings.tcl and the current command file in a zip file and also automatically sets this environment variable (HM_DONOT_READ_SETTING_FILES). This prevents reading the setting files during the subsequent invoke. You can also set this environment variable manually even if you don’t run into an invoke crash knowing that it will skip reading the setting files during invoke.
The subsequent launch after the invoke crash notifies you about the crash with a pop up message with additional details.
- User interface layout settings such as tab locations, panel location, command window, and tooltar location.
- Keyboard preferences.
- Import/export settings.
- Recently opened files.
- Other varions settings.
Examples
To set the mode to skip reading the setting files during invoke: HM_DONOT_READ_SETTING_FILES 1.
None.
