HM_FRAMERATE
Displays the graphics rotation frame rate in the command window.
HM_FRAMERATE val
HyperMesh Environment Variable
val
Any value turns on the frame rate output.
Examples
To enable the frame rate display: HM_FRAMERATE 1.
None.
