Close File
This function closes a previously opened file. This function returns (1) if the file is found and closed or else (0).C Calling Sequence
int c_rto_close_file(const char *fName);
Arguments
Argument | Type | Description | |
fName | Character Array | Input | File path |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_CLOSE_FILE_F2C(char *CHTDST, int dummylen, int *NCHTDS,
int *RETURN_VAL)
Arguments
CHTDST | Character Array | Input | File path |
NCHTDS | Integer | Input | The number of characters in the FileName. |
RETURN_VAL | Integer | Output | If file is found and closed then it returns 1 or else 0. |
