Read Table in a Block
This function locates the start of a table in a block in a file. The table is denoted using “{“ and “}”.C Calling Sequence
int c_rto_start_table_read(const char *block, char *form);
Arguments
Argument | Type | Description | |
block | Character Array | Input | This contains the block name in a TeimOrbit file. |
form | Character Array | Output | This contains the table column headings. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_START_TABLE_READ_F2C(char *blockName, int len1, int
*blockNameLen, char *format, int len2, int *formatLen, int *success)
Arguments
blockName | Character Array | Input | This contains the block name in a TeimOrbit file. |
blockNameLen | Integer | Input | This contains the number of characters in the block name. |
format | Character Array | Output | This contains the table column headings. |
formatLen | Integer | Output | This contains the number of characters in the format string. |
success | Integer | Output | If the value is read then success return 1 or else 0. |
