Read Real
This function reads the real value assigned to an attribute from the specified block.C Calling Sequence
int c_rto_read_real(const char *block, const char *attrib, int *alen, double
*dval);
Arguments
Argument | Type | Description | |
block | Character Array | Input | This contains the block name in a TeimOrbit file. |
attrib | Character Array | Input | This contains the name of the attribute inside a block. |
alen | Integer | Input | This contains the number of characters in the attribute name. |
dval | Double precision | Output | This returns the value of the attribute. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_READ_REAL_F2C(char *blockName, int len1, int *blen, char
*attributeName, int len2, int *alen, double *dval, int *success)
Arguments
blockName | Character Array | Input | This contains the block name in a TeimOrbit file. |
blen | Integer | Input | This contains the number of characters in the block name. |
attributeName | Character Array | Input | This contains the name of the attribute inside a block. |
success | Integer | Output | If the value is read then success return 1 or else 0. |
