FMETHOD
Subcase Information Entry Used to specify the parameters for aerodynamic flutter analysis, by referencing a FLUTTER Bulk Data Entry.
FMETHOD = option
Argument | Options | Description |
option | <ID> |
No default (Integer > 0) |
- This entry is required for a flutter analysis.
- The CMETHOD Subcase Information Entry must also be specified when K-method of flutter analysis is used.
