MBSIM
Subcase Information Entry The MBSIM command can be used to select a Multibody simulation definition to be applied in a Multibody problem.
MBSIM = option
- Only one MBSIM entry can be present for each subcase.
- This Subcase Information Entry is only valid when it appears in a Multibody subcase.
- MBSIM can be used to select only one Bulk Data Entry. MBSEQ, MBSIM, and MBLIN must have unique IDs.
