Safety Tools
Use the Safety ribbon to access crash and safety post-processing tools.
Figure 1. Safety ribbon in HyperGraph
Vehicle Crash Regulation Tools
- Load Case > Front Impact
- From the Load Case group, click the arrow next to the front impact icon,
                                 , to select the following
                                tools: , to select the following
                                tools:- IIHS Front (40%)
- IIHS Front (25%)
- MPDB (HyperView only)
- Load Case > Side Impact
- From the Load Case group, click the IIHS Side icon,  , to display the tool. , to display the tool.
- Load Case Menu
- From the Load Case drop-down menu, select the following post-processing
                                tools:- Compare Time History
- Door Intrusion
- Relative Displacement
Vehicle Impact Regulations Tools
- Click the Pedestrian icon,  , to access the pedestrian impact
                        post-processing tools for head, lower-leg, and upper-leg simulations
                        analysis in accordance with Euro-NCAP, GTR, and C-NCAP regulations. , to access the pedestrian impact
- Click the Instrument Panel icon,  , to access the post-processing tool
                        for FMVSS201 and ECE-R21 regulations. , to access the post-processing tool
Dummy Injury Criteria
Figure 4.
