Tutorials
View tutorials for Design Explorer workflows.
View new features for HyperWorks 2022.2.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints.
An input design variable is a system parameter that influences the system performance in the chosen output response. Typical design variables may be a part's thickness, shape, or material property. Ranges, with lower and upper bounds, are specified and the variable's value will vary within the exploration. The terms input, input design variable, and design variable are used interchangeably.
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Objectives are metrics to be minimized or maximized in an optimization exploration. Minimizing mass to find a lightweight design is a common example.
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Review the explorations, inputs, responses, and goals in your design setup.
Use the Evaluate tools to run the exploration and review reports.
In this tutorial, you will learn how to perform a design of experiments (DOE) using the Design Explorer workflow.
In this tutorial, you will learn how to perform an optimization using the Design Explorer workflow.
In this tutorial, you will learn how to use some of the Artificial Intelligence tools exposed in Design Explorer by creating a design of experiments (DOE) and training an ML model using the Design Explorer workflow.
ON THIS PAGE
ON THIS PAGE
