Export Files
Export various file types from the selected client to another format.
During export you can write information from a HyperMesh database to many finite element formats. However, geometry data can only be written in IGES format.
Use the Custom option to export models using your own custom-built export translator, or export models using a translator provided with the HyperWorks installation but which is not directly accessible via the default Export file types.
  1. Do one of the following:
    • From the menu bar, select File > Export > <file type>.
    • Press Ctrl + E.
    Depending on the client you are using, the following file types can be exported: models, geometry, solver decks, BOMs, connectors, H3D binary files, curves, markers, output text, CSV tables, and custom data files.
  2. In the Export File dialog, enter a name for the file and save it to your working directory.
  3. If needed, define any options in the Export Options dialog and then click Export.
