HyperWorks
HyperWorks
2022.2
  1. Home
  2. Plot Data
  3. 3D Chart
  4. Define
    Edit existing curves or add new curves to the current plot.
  5. Use Values as a Data Source
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.2
HyperWorks
  • What's New
    View new features for HyperWorks 2022.2.
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
    • Bar Chart
    • Complex Chart
    • Polar Chart
    • Vector Chart
    • Radar Chart
    • 3D Chart
      • Create Curves by File
        Loads Flux motor efficiency files in text format.
      • Define
        • Add a Curve
        • Copy and Paste Data Point Values
        • Cut Data Point Values
        • Cut, Copy, and Paste Curves
        • Display the Curves Dialog
        • Edit a Curve with File as a Data Source
        • Insert Data Point Values
        • Rename a Curve
        • Turn a Curve On or Off
        • Use File as a Data Source
        • Use Math as a Data Source
        • Use Values as a Data Source
      • Waterfall
        Create waterfall plots from XY force response data and input pulses.
      • Curve Style
        Define curve attributes.
      • Axes
        Axes can be added to plots using the Axes panel.
      • Values
        Retrieve individual point data on any curve in the active window.
      • Data Query
        The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
      • Annotate
        Provides quick access to the Datums and Notes tools.
      • 3D Chart Context Sensitive Menu
        From the HyperGraph 3D3D Chart modeling window, right-click to display the context menu.
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.2
  1. Home
  2. Plot Data
  3. 3D Chart
  4. Define
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  1. From the Define panel, select Values.
  2. Enter values in the table.
  3. Click Apply.
