Building a Two-Wheeler Model with an Aerodynamic System
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
- Starting the Assembly Wizard.
              - In a MotionView session, click  and select Two wheeler as the Wizard
                    Library. Figure 1. Figure 1.
- Click .The Two wheeler - Model Type dialog opens.
- Select the Full motorcycle with driver option and click
                    Next. Figure 2. Figure 2.
- Select the Aerodynamic Forces in the additional systems
                  tab and complete the model selection.  Figure 3. Figure 3.
- The Full vehicle with driver model including the aerodynamic forces system build
                  through the Assembly Wizard is displayed in the graphics area. Figure 4. Figure 4.
- Click on the Aerodynamic Forces system to display the
                  Attachments section in the panel area. Figure 5. Figure 5.Attachments Description Vehicle Body (Body) Vehicle body where the action forces of the Aerodynamic system is applied. Vehicle Body CG (Point) Center of gravity point of the vehicle.
- Under Data Sets, the aerodynamic property file is defined. Figure 6. Figure 6. Figure 7. Figure 7.
- The Center of pressure point (p_center_of_pressure),
                  where the aerodynamic forces are applied, is by default parametrized with the
                  Center of Gravity of the vehicle using the Attachment Vehicle Body CG
                    (Point) (p_veh_bdy_cg). By either entering the center pressure point
                  in the Attachment or modifying the coordinates of the Center of
                    Pressure point it is possible to specify the location of the
                  aerodynamic force applications. Figure 8. Figure 8.
                    Library.
