Property File
Aerodynamic system uses aerodynamic property file (.aae) to provide access to all the parameters to the solver. The reference to the .aae file is sent to the solver as a Solver String in the sa_aero_params solver array.
- TiemOrbit Format
- The TeimOrbit reader can parse various entities to get data from the aerodynamic
              property file. These entities include: attributes, blocks, sub-blocks, tables, units,
              and comments.- Attributes
- Attributes form the smallest data member of the driver file. Attributes can be
                    real, integer, strings or Booleans (True/False).
                      [BLOCK_NAME] ATTRIBUTE_1 = 'TRUE' ATTRIBUTE_2 = 1.0 ATTRIBUTE_3 = 'Wind_velocity' ATTRIBUTE_4 = 8Attribute names are:- Strings
- Case insensitive, for example: TAG and tag are equivalent.
- In the above example, the attributes are: TAG, SATURATION, LOOK_AHEAD_TIME, DEMAND_FILE, INTEGRATION_STEP_SIZE are the attribute names.
 Attribute value:- Real, integer, string, bool
- Strings should be written in ‘single quotes’ or “double quotes”
- 0, 0.00, N, NO, FALSE, F are all depicted as false
- 1, 1.00, T, TRUE, Y, YES are all depicted as true
- Case sensitive
 Format:ATTRIBUTE_NAME = ATTRIBUTE_VALUE
- Block
- Blocks form the most versatile data structure of the reader utility. It acts
                    as container for all other data members except a block.- Block can contain any number of sub-blocks.
- Block cannot contain a block.
- Block can contain multiple tables but only storing them in different sub-blocks.
 Format:[BLOCK_NAME] ATTRIBUTE(s) SUBBLOCK(s) TABLEBlock ends with the end of file or start of new Block.
- Sub-block
- Sub-blocks are structurally similar to blocks with an only difference that
                    they cannot contain sub blocks or blocks.- A sub block cannot contain more than one table.
 Format:(SUBBLOCK_NAME) ATTRIBUTE(s) TABLE(s)
- Table
                    Data structure which consists of fields (rows and columns).- Table can contain any type of attributes.
- In no label is provided, the default is to label them as indices starting from 0.
 Format:{LABEL1 LABEL2 LABEL3} ATTRIBUTE00 ATTRIBUTE01 ATTRIBUTE02 ATTRIBUTE10 ATTRIBUTE11 ATTRIBUTE12 ATTRIBUTE20 ATTRIBUTE21 ATTRIBUTE22
- Units
                    ‘Units’ is a special block that conveys the reader units of the property file.- Every property sheet should necessarily have a units block.
- User defined units in tables.
- Comment
- Anything written in line after ‘$’ is ignored by the reader
                    utility.[ENVIRONMENT] $These are environment conditions for the simulation GAS_CONSTANT = 287e3 AMBIENT_PRESSURE = 0.101325 AMBIENT_TEMPERATURE = 298 WIND_VELOCITY = 'WIND_VELOCITY'
- Altair Header
- The Altair header block provides the basic information of the property file to the
                solver.$-----------------------------------------------------------------ALTAIR_HEADER [ALTAIR_HEADER] FILE_TYPE = 'AAE' FILE_VERSION = 1.0 FILE_FORMAT = 'ASCII' ENTITY_TYPE = 'AERODYNAMIC_FORCE'Type Requirement Block name [ALTAIR_HEADER]String REQUIRED FILE_TYPE Attr-String REQUIRED - Read and extract information
- Multiple file format support
 FILE_VERSION Attr-Real REQUIRED FILE_FORMAT ‘ASCII’Attr-String OPTIONAL Optional currently, required for future enhancement.ENTITY_TYPE 'AERODYNAMIC_FORCE'Attr-String OPTIONAL Provides info on the entity associated with the property file.
- Units
- Solver parses the AAE in MotionSolve during the simulation to extract aerodynamic
              and environment data. While parsing the property file, solver reads the units block to
              convert data in the property file to SI units and use them further in the
                simulation.Units block specifies the units of all the data mentioned in the property file. The units are specified for length, force, angle, mass, time and temperature.- Units are not case sensitive – meter, Meter, METER, or MeTer are all interpreted as same.
- Units block is require for all types of data files.
 $--------------------------------------------------------------------------UNITS [UNITS] (BASE) {length force angle mass time temperature} 'mm' 'newton' 'degrees' 'kg' 'sec' 'kelvin'Dimension Options Conversion Factor to SI Length meter or meters or m foot or feet or ft mile or miles millimeter or millimeters or mm inch or inches or in1.0 0.3048 1609.344 0.001 0.0254Force Newton Dyne KNewton Ounce_Force Kilogram_Force or Kgf KPound_Force Pound_Force or lbf 1.0 0.00001 1000 0.27801 9.80665 4448.2216 4.4482216Angle Radian or radians or rad or r Degrees or degree or deg or d1.00 0.017453Mass Kg or kilogram or kilograms G or gram or grams Pound or pounds or lb or lbs1.0 0.001 0.453592Time sec or second or seconds milliseconds or millisecond or millisec or millisecs or ms1.0 0.001Temperature Kelvin or k Note: More temperature units will be supported in upcoming versions.1.0
- Geometric properties
- This section contains the data related to vehicle geometry. Calculation of the
              aerodynamic forces require the frontal area of the vehicle which is specified in this
                block.$---------------------------------------------------------------GEOMETRIC_PROPERTIES [GEOMETRIC_PROPERTIES] FRONTAL_SECTION_AREA = 2e6Block name [GEOMETRIC_PROPERTIES]String REQUIRED FRONTAL_SECTION_AREA Attr-Real REQUIRED Frontal area of the vehicle. Unit – L2
- Environment
- This section contains the data related to the environment. Calculation of the
              aerodynamic forces require the ambient pressure, ambient temperature and wind velocity
                block.$---------------------------------------------------------------ENVIRONMENT [ENVIRONMENT] GAS_CONSTANT = 287e3 AMBIENT_PRESSURE = 0.101325 AMBIENT_TEMPERATURE = 298 WIND_VELOCITY = 'WIND_VEL_1' $Wind vel is with respect to global frame $---------------------------------------------------------------WIND_VELOCITY [WIND_VEL_1] $Wind vel is with respect to global frame VX = 1000 VY = 0 VZ = 0Type Requirement Block name [ENVIRONMENT]String REQUIRED GAS_CONSTANT Attr-Real REQUIRED Unit – FLM-1Temp-1AMBIENT_PRESSURE Attr-Real REQUIRED Unit – FL-2AMBIENT_TEMPERATURE Attr-Real REQUIRED Unit – TempWIND_VELOCITY Attr-STRING Reference to another block having wind velocities (Vx, Vy, Vz) REQUIRED Unit – LT-1
- Drag Coefficient
- This section contains the table of drag coefficients with respect to different
              incidence angles. The table is provided as a spline as shown in the block and the
              interpolation scheme is provided. This block is applicable for both three-point and
              single-point
                implementation.$---------------------------------------------------------------DRAG_COEFFICIENT [DRAG_COEFFICIENT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [DRAG_COEFFICIENT]String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 If present:- Interpolation scheme = INTERPOLATION.value.
- Options - AKIMA, CUBIC, LINEAR, QUINTIC.
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Drag coefficient values at different values of incidence angles
- Side Force Coefficient
- This section contains the table of sideforce coefficients with respect to different
              single-point
                implementation.$--------------------------------------------------------------- SIDEFORCE_COEFFICIENT [SIDEFORCE_COEFFICIENT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [SIDEFORCE_COEFFICIENT]String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Sideforce coefficient values at different values of incidence angles
- Lift Coefficient
- This section contains the table of front lift coefficients with respect to different
              interpolation scheme is provided. This block is only applicable for single-point
                implementation.$--------------------------------------------------------------- LIFT_COEFFICIENT [LIFT_COEFFICIENT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [LIFT_COEFFICIENT] String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Front lift coefficient values at different values of incidence angles
- Front Lift Coefficient
              interpolation scheme is provided. This block is only applicable for three-point
                implementation.$--------------------------------------------------------------- LIFT_COEFFICIENT_FRONT [LIFT_COEFFICIENT_FRONT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [LIFT_COEFFICIENT_FRONT] String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
- Rear Lift Coefficient
- This section contains the table of rear lift coefficients with respect to different
                implementation.$--------------------------------------------------------------- LIFT_COEFFICIENT_REAR [LIFT_COEFFICIENT_REAR] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [LIFT_COEFFICIENT_REAR] String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Rear lift coefficient values at different values of incidence angles
- Roll Coefficient
- This section contains the table of roll coefficients with respect to different
                implementation.$--------------------------------------------------------------- ROLL_COEFFICIENT [ROLL_COEFFICIENT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [ROLL_COEFFICIENT] String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Roll coefficient values at different values of incidence angles
- Yaw Coefficient
              This section contains the data related to vehicle geometry. Calculation of the aerodynamic forces require the frontal area of the vehicle which is specified in this block. This block is only applicable for three-point implementation. $--------------------------------------------------------------- YAW_COEFFICIENT [YAW_COEFFICIENT] INTERPOLATION = 'AKIMA' (SPLINE_DATA) {INCIDENCE_ANGLE COEFFICIENT} 0.0 0.3 10.0 0.31 20.0 0.32 30.0 0.33Type Requirement Block name [YAW_COEFFICIENT] String REQUIRED INTERPOLATION Attr-String OPTIONAL If absent:- Interpolation scheme = AKIMA
 These interpolation schemes are similar to those of Altair MotionSolve. See the Altair MotionSolve documentation for details on interpolation schemes. SPLINE_DATA Attr-Table INCIDENCE_ANGLE vs COEFFICIENTREQUIRED Yaw coefficient values at different values of incidence angles
