Reviewing Maximum Penetration Depth
The steps to access the contact overview results for the simulation are:
                Select Contact Overview in the Results Browser in the left of the window:
                Select the Contour button in the toolbar:
                Select the Contour Penetration Depth (s) for the Result
                    type in the panel:
 Figure 3.
                Select Components in the Selection input
                    collector:
 Figure 4.
                Select the graphics in the graphics window.
 Figure 5.
                Click Apply.
 Figure 6.
                Inspect the results.
 Figure 7.Tip: The overview results are best seen if you change the opacity of the body graphics:- Select the opacity tool in the toolbar and select
                                    Transparent Elements and Feature Lines
                                from the drop-down menu.
 Figure 8.
