Animate Flexible Body Results and View Contours in HyperView
                Click the Open Model button  on the Standard toolbar, or from the File menu select Open > Model.
                See Opening Files in HWD for additional information. on the Standard toolbar, or from the File menu select Open > Model.
                From the Load Model panel, verify that the Load model and Load results check
                    boxes are activated.
                 Figure 1. Figure 1.
                Click the Load model file browser  .
                The Load Model File dialog is displayed. .
                Open the ALTAIR.flx file.
                The same file is automatically loaded into the Load results field.
- Click Apply.
                Click the Start/Pause button  on the Animation toolbar to animate the results. on the Animation toolbar to animate the results.
                Click the Contour panel button  located on the Results toolbar.
                The Contour panel is displayed. located on the Results toolbar.
- Use the Contour panel to view displacement or stress contours on the model.
