View new features for HyperWorks 2022.2.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
MotionView works with a HyperWorks neutral file called H3D to represent the flexible body. This compact file format stores the necessary information for visualizing the flexbody in the pre-processing window and the modes and interface nodes in the post-processing window. It also stores the modal and nodal information.
Once an H3D file is created, it can be visualized in HyperView.
MotionView models solved in MotionSolve or Adams can be animated in HyperView. In addition, the plots for these models can also be viewed in HyperGraph.
HyperView supports post-processing of transient analyses and modal (ADAMS Linear) analyses of ADAMS simulations that contain flexbodies.
From the Preferences dialog, you can access various MotionView options for your model.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
Figure 1. © 2023 Altair Engineering, Inc. All Rights Reserved.
