Building a Full Vehicle Model with Advanced Drivers
Next we will go step by step from one window to another and explain the available options in each window to have a better understanding of the Assembly Wizard’s Full Truck with Advanced Driver model type.
- Select the Full vehicle with advanced driver option from the Model Type window and click Next.
                Select the Front wheel drive option for the model and click
                        Next.
                Select the primary systems for the model as shown in the following image and
                    click Next.
                Select the steering subsystems for the model as shown in the following image
                    and click Next.
 Figure 3.
                Select the springs, dampers, and stabars for the model as shown in the
                    following image and click Next.
 Figure 4.
                Select the jounce and rebound bumpers for the model as shown in the following
 Figure 5.
                Select the disk brakes and front drivelines for the model as shown in the
 Figure 6.
                Now, select the Advanced Driver system and click
                        Next.
 Figure 7.Note: The Advanced Driver is now included as a system.
                Now that you have selected all the required systems for the model, click the
                        Finish button to complete the assembly process and
                    exit the Assembly Wizard.
 Figure 8.Note: Click Attachments button to proceed with the Attachment Wizard.
                The Full Truck with Advanced Driver model built through the Assembly Wizard is
                    displayed in the graphics area.
 Figure 9.
- The subsystems you have selected in the Assembly Wizard to build the model are displayed in the Project Browser.
