This section describes how to build events in the full vehicle model with Altair Driver. The new event user interface is supported only for models
    with Altair Driver. The interface exports .adf
    and .xml files and submits them to MotionSolve.
    Files can be edited or updated in the Event Editor. Eighteen event types are
    supported.
    Building a Vehicle Model with Altair Driver
      In
MotionView, models are assembled from libraries of
        pre-defined systems using the Assembly Wizard. The
Assembly Wizard
        dialog guides you through the assembly process, ensuring that your selections are
          compatible.
Note: The MBD Vehicle Dynamics Tools preference files must be loaded before
          using the event builder. Select  from the MotionView interface.
