Saving Model Files
                From the File menu select Save > Model.
                Or From the Home tools, Files tool group, click the Save Model tool.
 Figure 1.Note: If the model in the data base is a new model, a dialog will be displayed. However if the model already has a file name, it will be saved directly (no dialog will be displayed).
                From the Save As Model dialog, specify a file name and
                    click Save.
                The model is saved.
