Brake Steer
Request Number: 80000260
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Braking Force Steer | deg/g | The left wheel change in steer angle induced by vehicle braking. See brake
                  dive/lift above for calculation of intermediate terms.
| F3 | RESULT(3) | Right Braking Force Steer | deg/g | The right wheel change in steer angle induced by vehicle braking. See brake
| F4 | RESULT(4) | Average Braking Force Steer | deg/g | The mean of the left and right braking force steer. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Braking Force Windup | deg/g | The left wheel change in caster angle induced by vehicle braking. See brake
| F7 | RESULT(7) | Right Braking Force Windup | deg/g | The right wheel change in caster angle induced by vehicle braking. See brake
| F8 | RESULT(8) | Average Braking Force Windup | deg/g | The mean of the left and right braking force windup. |
