Roll Inclination
Request Number: 80000200
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel Roll Inclination | % (deg/100 deg) | The left wheel camber angle change with respect to the true ground line (line
                  connecting tire patches) due to out-of-phase vertical deflections of the left and
                  right tire patch points expressed in degrees of axle roll
                      or: track = abs((right wheel center y) - (left wheel center y)) deltaz = C(3,3)-C(3,9)-C(9,3)+C(9,9)+2/(tire stiffness)
| F3 | RESULT(3) | Right Wheel Roll Inclination | % (deg/100 deg) | The right wheel camber angle change with respect to the true ground line
                  (line connecting tire patches) due to out-of-phase vertical deflections of the
                  left and right tire patch points expressed in degrees of axle roll
| F4 | RESULT(4) | Average Roll Inclination | % (deg/100 deg) | The mean of the left and right wheel roll inclination. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Not Used | Not Used | Not Used |
| F7 | RESULT(7) | Not Used | Not Used | Not Used |
| F8 | RESULT(8) | Not Used | Not Used | Not Used |
