Set Wizard Paths Dialog
The Set Wizard Path dialog allows you to select directories in which several files are stored.
- Assembly Wizard file
 - Task Wizard file
 - MDL standard include file
 - Wizard library directory
 - Report log file
Figure 1. Set Wizard Paths Dialog
- OK
 - Applies the changes and exits the dialog.
 - Cancel
 - Exits the dialog.
