Delete Cached Results
                Delete the internal cache of the active contour result using one of the
                    following methods.
                - From the Contour panel panel, click Delete cache.
- Right-click on the browser data item and select Delete from the context menu.
- To delete all of cached results simultaneously, right-click on the Cached results folder in the browser and select Delete from the context menu.
