View new features for HyperWorks 2022.2.
The Image Plane tool allows you to select and overlay images (such as company logos, watermarks, etc.) or videos in the graphics area for correlation and presentation purposes.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
