Select a Projection Rule
  1. From the Plot tools, click the Iso tool.
  2. From the Iso panel, click the Projection Rules button.
    The Projection Rule dialog is displayed.
  3. Select the primary and secondary axes from either the global or user-defined system (selected for Resolved in).
    When the primary axis is perpendicular to the shell plane, the secondary axis is used.
    See the Projection Rule topic for additional information.
