Edit the Contour, Vector, or Tensor Panel Legend
                From the Contour, Vector, or Tensor panel, click Edit
                        Legend.
                The Edit Legend dialog is displayed.
                Select the attributes that you want to apply to the legend.
                The changes are previewed on the sample legend, located on the right side of the dialog.
 - Click Apply to apply the changes to the legend.
 - Optional: Click Default to restore the default values for the legend.
 - Click OK to exit the dialog.
