Importing a .csv File into Excel
View new features for HyperWorks 2022.2.
Query and view key information about selected entities live when in idle mode.
Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
Use the Plots tool to construct multiple curves and plots from a single result file.
In version 2021, the Stress Linearization tool was renamed as Extract-Linearize and now supports both the Extract Data and Stress Linearization methods. Starting in version 2022.2, Strain Linearization will also be supported.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities based on selection set, threshold values, minimum separation, and load cases. In addition, you can plot the search results with annotations and selective amount of details displayed on screen.
The Quick Hotspot tool helps you find the entity with the highest or lowest result value in a given selection and display this information in a Note.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
