BCMatToElem
Converts material values to elemental values.
- src
- A property value table.
- elems
- An element entity table.
- parts
- A part entity table.
- props
- A property entity table.
- mats
- A material entity table.
- layer_idx
- Layer index.
- layer_label
- Selected layer label.
Outputs
- answer
- An elemental value table.
- If src is a vector or tensor table, it should be transformed to the global coordinate system.
- Aggregation modes are not applicable for this operation.
- layer_idx = layer index for the chosen data type, assigned by the HyperWorks application, and defaults to the value “@current_slice_index”. @current_slice_index represents the layer index for the chosen datatype.
- layer_label = layer label for the chosen data type, assigned by the HyperWorks application, and defaults to the value “@current_slice_label”. @current_slice_label represents the layer label for the chosen data type, and is used to determine the layer ID in cases where an index-based layer lookup is invalid.
- The XML example below does not specify layer_idx or layer_label and uses the defaults.
- The Expression Builder will provide default values for layer_idx and layer_label.
BCMatToElem(src,elems,parts,props,mats,layer_idx,layer_label)XML Example
<call name="BCMatToElem" src="mat_val_tab" elems="elem_tab"
parts="part_tab" props="prop_tab"
mats="mat_tab" answer="ans_tab" />
