Delete a Set
- From the Create tools, select Create > Sets.
                From the Set panel, select a set/group.
                Tip: Multiple sets can be selected to be deleted.
                Delete the set(s) using one of the following methods.
                - Click Delete (located at the bottom of the panel).
- Press the Delete key on the keyboard.
 The selected set is removed from the list.
