Delete a Tracking System
- From the Create tools, select Create > Tracking Systems.
                Select a tracking system from the Tracking Systems list.
                Note: Multiple tracking systems can also be selected.
                Delete the tracking system(s) using one of the following methods.
                - Click Delete (located at the bottom of the panel).
- Press the Delete key on the keyboard.
 The tracking system is removed from the list.
