FBD Forces
Calculate the contribution of one or more elements to the force and moment equilibrium at desired nodes.
From the Post ribbon, click the Force tool.
The tool contains the following:
Free Body Sections
Define one or more cross-sections or groups of elements
Properties
Shows all properties of the selected free-body section
Loadcases
The loadcases available inside all of the imported result files
FBD Plot and Display
Visualization options
Free-body sections can be defined by selecting explicitly a group of elements and (optionally) which nodes of this group to be considered for the contribution of forces and moments (standard section type). They can also be defined using a cutting plane, which defines a dynamic cross-section. In this case all of the elements intersected by this plane will be considered as defining such cross-section, while the nodes belonging to these elements at one or another side of the plane will be considered for the calculation. It is possible to realize a cross-section type into a standard one.
The workflow is:
  1. Create or import free-body sections
  2. Set the properties of a selected free-body section
  3. Select a loadcase
  4. Set the options of the free-body plot
  5. Plot free-body forces and moments for the selected loadcase
Create or Import Free-Body Sections
Right-click and select Create or Import from File.
Free-body sections can be imported from .csv files or from Nastran’s Monitor Points 3 (.bdf files).
All free-body sections that are created are visible in the Model Browser.
Set Properties of a Selected Free-Body Section
  1. Select a free-body section.
    The properties display.
  2. Right-click on one (or multiple) free-body sections to:
    • Import or export its definitions from a .csv file or Nastran Monitor Point 3.
    • Realize cross-sections.
    Name
    The name of the selected free-body section.
    ID
    The ID of the selected free-body section.
    Color
    The color of the selected free-body section
    Entity id list
    This option is mandatory. Defines a group of elements for standard section or a cross-section.
    Node id list
    This option is exclusive for element selection. It is used to define the nodes that will be included in the free-body calculation. If the selection is empty, the free-body calculation will use all nodes belonging to the selected elements.
    Resolve in
    Defines the coordinate system used in the calculation. Options vary depending on the solver.
    Summation Point Type
    Defines where free-body forces and moments will be summed. The centroid will be calculated based on the nodes that are stored inside the Node id list. If the Node id list is empty, the free-body calculation uses all nodes belonging to the selected elements.
    Summation Node
    Defines a node where free-body forces and moments will be summed.
    Summation Point
    Defines the coordinates of the point where free-body forces and moments will be summed.
Select a Loadcase
Select a loadcase to plot free-body forces and moments.
Figure 3.
Define visualization options for the free-body plot.
Free body forces/moments
Defines whether free-body forces and moments must be shown at each boundary node or at all nodes. If the section group is made up only by elements and the node ID list is empty, the boundary nodes option searches for all of the nodes that are shared with the rest of the model.
Figure 4. All Nodes Option
Figure 5. Boundary Nodes
Figure 6. Boundary Nodes
Resultant forces/moments
Defines that free-body forces and moments must be shown at the summation point that is defined. If more than one option is selected, forces and moments are summed up.
If a cross-section is defined more options are available.
Cross Section Position
Moves the cross-section plane along its normal direction within the boundaries of the model. If the cross-section is realized, this option will not be available.
Flip
Allows you to select nodes that are on the opposite side of the cross-section’s plane normal. If the cross-section is realized, this option will not be available.
Figure 7.
Figure 8.
Figure 9.
Tables
Creates tables with free-body forces and moments for one or multiple sections and for one or multiple loadcases. The summary table (and summary table summation points) can be used to create Potato/VMT plots.
The summary table shows all forces and moments for nodes and summation points.
Figure 10.
The summary table summation points show all forces and moments at summation points only.
Figure 11.
The min/max table shows the higher and lower values of forces and moments at summation points among the selected loadcases.
Figure 12.
Load Creation
Creates an include file, where free-body forces and moments are properly realized as loads for that model for selected sections and selected loadcases.
Resolve In
Defines the coordinate system in which the loads will be created. Options vary depending on the solver.
Include Name
Defines the name of the include file in which the loads will be exported.
Forces
Selects force components to be exported.
Moments
Selects moment components to be exported.
Create Fields
Create field entities with free-body forces and moments for the selected sections and selected loadcases.
Load Types
Select what type of free-body data must be shown. Options vary depending on the solver. If more than one option is selected, values at the same location are summed up.
Tolerance
Forces or moments with an absolute value lower than the tolerance are not displayed.
Forces
Defines which force components will display.
Moments
Defines which moment components will display.
Show Values
Defines if free-body vector values will display.
Size Scaling
Defines how free-body vectors will be scaled for visualization.
Arrow Length (%)
Scales free-body vectors for visualization.
Color
Change the color of each force or moment component.
Vector Heads
Defines if the free-body vector points to the node or out of it.
Vector Style
Change the style of free-body vectors.
Numeric Format
Defines if free-body vector values should be displayed in fixed or scientific format. It also defines the amount of decimal places.
Plot Free-Body Forces and Moments
Plot free-body forces and moments for the selected loadcase.
  • On the FBD Plot tab, click Apply to show free-body vectors.
  • On the FBD Plot tab, click Clear to hide vectors.
Figure 13.
Free Body CSV File
The FBD Forces tool can import or export one or more cross-sections using the .csv file format.
Below is an example:
Figure 14.
Figure 15. Displayed in a Calculation Sheet Software
Section Name
The free-body section's name.
Section Color
The free-body section's color.
Section Type
Defines the type of the free-body section. The standard type corresponds to a realized cross-section. The cross-section type has not been realized. Therefore, you can change the cross-section position.
Element List
Defines a list of elements for the standard type or the coordinates of a base point for the cross-section type.
NodeList/Normal
Defines a list of nodes for the standard type or the coordinates of a point for the cross section type. This point, together with the base point defined on Element List/Normal, will establish a normal vector.
SumPointType
Defines where forces and moments will be summed up.
SumPointValue
If the summation point is at the centroid it must be left empty.
If the summation point is at a node it must store a node ID.
If the summation point is a position it must store coordinates.
ResolvedInSystem
Defines which coordinate forces and moments should be plotted.
SystemId
If the ResolvedInSystem System is the analysis or global system, it must store 0.
If the ResolvedInSystem System is User System, it must store a Coordinate System ID.
The FBD Forces tool can export one or more cross-sections using Nastran’s Monitor Point 3 Format (.bdf file).
Figure 16.
