Workflow
Examples of a typical workflow that can be followed to define a composite model in HyperMesh. The order of steps provided does not need to be strictly followed but should be used as a template.
View new features for HyperWorks 2022.2.
Pre-processing in HyperMesh.
An introduction to composites terminology and modeling methods.
Stacking direction of plies in a laminate.
Reference orientation of plies.
Material definition.
Composite shell model definition.
Drape simulation.
Conversion between ply-based and zone-based models.
Tools for visualizing orientations, ply shapes and ply layers.
Import and export composite data.
Use the Composite Browser to create, organize, and manage composite modeling data.
Entities that comprise composite parts.
Utilities for working with composite models.
Use the Injection Molding ribbon to facilitate the development of accurate structural simulation models for reinforced injection molded parts and assemblies.
Composite stress toolbox functionality which supports calculation of engineering constants, compliance and stiffness matrices, parameterized joint and panel analysis, and other traditional hand-calculation methods.
Development of multiscale and single scale material models and simulation of parts manufactured from any heterogeneous and homogenous material.
ON THIS PAGE
ON THIS PAGE
