Create Bounding Solids
Use the Solids: Bounding tool to create solids from enclosed surface volumes.
View new features for HyperWorks 2022.2.
Explore the tools used to create geometry.
Learn about creating, editing, and extracting points and nodes.
Create and edit circles and rectangles with the Shapes tool.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Use the Solids: Sphere tool to create spheres with solid or bounding surfaces.
Use the Solids: Box tool to create boxes with solid or bounding surfaces.
Use the Solids: Cylinder tool to create cylinders with solid or bounding surfaces.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Drag/Spin tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, or lines.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Extract the midsurface of thin solids, and review and edit midsurface plates.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
to define additional
options.
Review each found/selected bounding surface group by clicking
and
