Create and Edit Rectangles
Use the Rectangles tool to create rectangles for geometry construction, edit free rectangles, and create/toggle filled rectangles.
New rectangles are organized in the same component as the entity where the center point is placed.
When there is ambiguity, the Rectangles tool switches between possible inferred normals.
- Clicking over a free line in space creates a rectangle on the line, normal to the line direction. Clicking over a line on top of a surface creates a rectangle on the line, but normal to the surface. Clicking in empty space creates a rectangle aligned with global coordinates.
 - Use snap points to snap to pre-defined points on your model such as end, middle, center, and intersection points.
 in the
