Interfacing with Abaqus
Overview of how the HyperView applications interface with the Abaqus solver.
Reading Abaqus INP, FIL, and OBD Files
Functionality HyperView
Animation Window Plot Window
Reads model file directly INP, ODB N/A
Reads results file directly ODB (field) ODB (field and history)
Reads translated results FIL (hmabaqus) FIL (hmabaqus)
FIL (hgopt_abaqus.exe)
Supported field results (typically contoured) FIL, ODB ODB
Supported history results (typically plotted) N/A FIL, ODB
Abaqus version supported 2022, 2021, 2020, 2019, 2018 2022, 2021, 2020, 2019, 2018
Retains model's component names and IDs INP, H3D from HM N/A
Coordinate Systems
Can transform results to other system type inside application Yes N/A
Abaqus Results for ODB
POSITION = INTEGRATION POINTS Yes Yes
POSITION = CENTROIDAL Yes Yes
POSITION = NODES Yes Yes
POSITION = AVERAGED AT NODES No No
Abaqus Results for FIL
POSITION = NODES No No
POSITION = AVERAGED AT NODES Yes Yes
Abaqus Entities
Supports 1-D elements model Yes Yes
Supports 1-D elements results Yes Yes
Supports mass entities in model No Yes
Supports symmetric results on cylindrical surface and solid elements Yes N/A
