Interfacing with ANSYS
Overview of how the HyperView applications interface with the ANSYS solver.
This section discusses how the HyperView applications interface with the ANSYS solver.
View new features for HyperWorks 2022.2.
Load a different solver interface in HyperWorks.
Supported solvers in HyperMesh.
Supported solvers in HyperView.
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
Overview of how the HyperView applications interface with the Abaqus solver.
Overview of how the HyperView applications interface with the ADAMS solver.
Overview of how the HyperView applications interface with the ADVC solver.
Overview of how the HyperView applications interface with Animator DB.
HyperView supports ANSYS elemental results (PLESOL) and nodal results (PLNSOL).
HyperView supports midside node results, and calculates midside node results for stress and strain tensors even though result output files do not have midside nodes.
A new script has been added for ANSYS result files, which allows you to extract total summation of nodal force and moments for the nodes of the selected elements.
Overview of how the HyperView applications interface with the EDEM solver.
Overview of how the HyperView applications interface with the I-DEAS solver.
Overview of how the HyperView applications interface with the LS-DYNA solver.
Overview of how the HyperView applications interface with the LS-NIKE3D solver.
Overview of how the HyperView applications interface with the MADYMO solver.
Overview of how the HyperView applications interface with the MARC solver.
Overview of how the HyperView applications interface with Moldflow.
Overview of how the HyperView applications interface with the Nastran solver.
Overview of how the HyperView applications interface with the OptiStruct solver.
Overview of the HyperViewnSOFT interface.
Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
Overview of how the HyperView applications interface with the Radioss solver.
AcuSolve results for steady state, transient and moving/deforming mesh analyses can be imported and post-processed using the AcuSolve Reader (*.log) in HyperView.
Load post-processing files using the Load Model panel.
Supported solvers in HyperGraph.
Solvers and translators supported in MotionView.
ON THIS PAGE
ON THIS PAGE
