Configure the Results Browser
Change the entity types, columns, options, and toolbars that are displayed in the Results Browser.
- Right-click in the Results Browser and select Configure Browser from the context menu.
- Use the Browser Configuration dialog to edit browser options, entities and toolbars.
                Click one of the command buttons to close the dialog.
                - Click Apply to append the new settings without closing the window.
- Click OK to keep the new settings, including those that are not applied, and close the window.
- Click Cancel to discard the changes that are not applied (keeping previous applied settings) and close the window.
- Change the columns/attributes that display in the Results Browser by right-clicking on a column heading and selecting check boxes in the microdialog.
