HyperWorks
HyperWorks
2022.2
  1. Home
  2. Validate
  3. Manage and Run Checks
    Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
  4. Supported Checks
    Supported default checks organized by solver interface.
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.2
HyperWorks
  • What's New
    View new features for HyperWorks 2022.2.
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
    • Run Model Quality Checks on Selected Entities
      Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
    • Manage and Run Checks
      • Context Menu
        Provides a variety of options for working with the Model Checker.
      • Create/Edit Checks and Corrections
        Create new checks and corrections, and edit default checks and corrections.
      • Organize Checks
        Organize new and existing checks inside of a user-defined Check Folder.
      • Configure Model Checker
        Save configurations for future use, import existing configurations into your current HyperWorks session, or append configurations on top of existing configurations.
      • Run Model Check
        Find all entities in your model that failed the active checks in the Model Checker.
      • Supported Checks
        • Abaqus
        • ANSYS
        • LS-DYNA
        • Nastran
        • OptiStruct
        • PAM-CRASH 2G
        • Permas
        • Radioss
      • Sample Script
        Use this sample script to run the Model Checker in batch mode.
    • Calculate Mass
      Use the Mass tool to calculate the mass, center of gravity (COG), and moments of inertia (MOI) of the model.
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.2
  1. Home
  2. Validate
  4. Supported Checks
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Supported Checks
  • Abaqus
  • ANSYS
  • LS-DYNA
  • Nastran
  • OptiStruct
  • PAM-CRASH 2G
  • Permas
  • Radioss
