Remove Links
Remove links from one or more connectors at a time.
Remove Links is available from the Connector Entity Browser's context menu when you right-click in the Entities or Link columns.
Once links are removed, updated connectors will be unrealized and your changes will be permanently updated in the database and browser.
Remove All Links From Connectors
- Select the connectors from the browser for which all the links needs to be removed.
- Open the default context menu by right-clicking in the Entities column of the tree list.
- Select Remove Links to confirm and execute the operation.
![](../../images/connector_browser_remove_links.png)
Remove Specific Links From Connectors
- Select the link(s) to remove, then right-click and select Remove Links from the context menu.
- In the Confirm dialog, click Remove link.
