Link regions and components: solid conductor
To link the regions of the solid conductor type (of the FE domain) to the components of the solid conductor type (of the electric circuit), follow the next procedure:
Step Action
1
In the Physics menu:
  • point on Assign solid conductor components to regions and click on Assign solid conductor components to face regions
Division of graphic zone in two and visualization of the FE domain in one zone and the electric circuit in the other
Display of the face regions of solid conductor type in the form of array
2
In the array*, fill out the zones for each region:
  • Associated solid conductor
  • Current orientation (positive or negative)
Note: * See figure below.
Array of solid conductors
The array corresponding to the regions of the solid conductor type (2D) is presented in the figure below.
In this array, the zones which allow the visualization of the regions (of solid conductor type) and of the electric components (of solid conductor type) are showed in the figure below.
