Link regions and components: solid conductor
Solid conductor …
With regard to solid conductors, the user must carry out for each component the following operation:
  • he defines a geometric terminal for each electric terminal of the M2 component (M2_PT002_1, M2_PT001)
Define geometric terminals
To define the geometric terminals (associated with the imported electric terminals) of the regions of solid conductor type follow the next procedure:
Step Action
1
In the Physics menu:
  • point on Assign terminals to solid conductors and click on Assign terminals to solid conductors 2/N terminals (…)
2
In the dialogue box Assign terminals …:
  • choose a solid conductor component
  • choose the type of terminals: external / internal
If external terminals If internal terminal
select faces corresponding to the M2_PT002_1 terminal select faces corresponding to the M2_PT002_1 / M2_PT001 double terminal
select faces corresponding to the M2_PT001 terminal select the orientation line
Realization of the electric terminal / geometric terminal link.
To check the links between the electric and geometric terminals follow the next instructions:
Edit the components … to locate the components in the circuit
Edit the electric terminals … to identify the geometric terminals
