Correction of geometric defects by type
Before starting
It is necessary to open the context for healing of CAD geometry as follows:
Step Action
1
Pass to the healing mode via the menu Geometry and click on Context healing of CAD geometry
The healing mode for geometry is activated.
Note: Click on to go back.
Cut line on point
To cut the line on a point:
Step Action
1
Activate the command via the menu Healing > Cut line > Cut line on point
A dialog box Cut line ... is opened.
2
Fill in the fields:
  • choose the number of line to cut
  • choose the number of point on line to cut
3
Validate the information:
  • click on OK
The line is cut into two.
Cut two lines on their intersection
To cut two lines on their intersection:
Step Action
1
Activate the command via the menu Healing > Cut line > Cut two lines on their intersection
2
Fill in the fields:
  • choose the first line number
  • choose the second line number
3
  • click on OK
The two lines are cut.
Extend line to point
To extend the line to a point:
Step Action
1
Activate the command via the menu Healing > Extend line > Extend line to point
A dialog box Extend line ... is opened.
2
Fill in the fields:
  • choose the number of line to extend
  • choose the number of point to reach
3
  • click on OK
The line is extended.
Extend line to line
To extend the line to other line:
Step Action
1
Activate the command via the menu Healing > Extend line > Extend line to line
2
Fill in the fields:
  • choose the number of line to reach
  • choose the number of point to extend
3
  • click on OK
Reduce continuous lines in one line
To reduce continuous lines in one line:
Step Action
1
Activate the command via the menu Healing > Reduce continuous lines in one line
A dialog box Reduce … is opened.
2
Fill in the fields:
  • enter the numbers of lines to reduce
  • choose the reduce type
3
  • click on OK
The lines are reduced in one line.
Merge two lists of lines
To merge two lists of lines:
Step Action
1
Activate the command via the menu Healing > Merge two lists of lines
A dialog box Merge … is opened.
2
Fill in the fields:
  • enter the numbers of lines to be replaced
  • enter the numbers of lines to replace
3
  • click on OK
The lines are replaced.
