Linear solvers: Advanced options
This section targets advanced users and wants to help understanding what solver parameters do. Most advanced users who wants to select manually the solver to use and not only the type of solver must change their user mode: Flux Supervisor > Options > User mode > Advanced, then close and reopen Flux to apply that change. In the advanced mode, the solving options box displays significantly more options for linear solvers. Here is the list of linear solvers for instance:
Type Solver Name Parallel Distributed
N/A Automatic solver [default] N/A N/A
Iterative ICCG[default] No No
IJCG No No
PETSc Yes Yes
GMRes No No
BICGStab No No
Direct SuperLU No No
Mumps (Local) [default] Yes No
Mumps (Distributed) Yes Yes
N/A Solver by user subroutine N/A N/A
N/A External solver N/A N/A
For parallel and distributed solvers, you can set computing parameters globally in Flux Supervisor > Options > System > Parallel computing. These parameters are used to set some default options for Mumps and PETSc, see parallel computing for more details.
Below the details of each solver parameter is provided.
ICCG and IJCG
ICCG and IJCG are iterative solvers which use the conjugate gradient for the solving and the incomplete Cholesky factorization of LDLT for the preconditioning. In steady State AC, ICCG and IJCG use the conjugate bigradient for the solving and the incomplete factorization LDU for the preconditioning
Options
Parameter Description
Precision for the Conjugate Gradient
Relative precision to satisfy before stopping the iterative process.
Default value: 1.0e-6
Maximum number of iterations for the Conjugate
Gradient
Maximum number of iterations to compute before stopping the iterative process. Two options are available to set the number of iterations:
  • A linear function which takes two integers as inputs (A and B) defined as:
    N = A   ×   n u m b e r   o f   d e g r e e s   o f   f r e e d o m + B
  • A fixed value N
Default value: Linear function with A = 1 and B = 1, which is the number of equations of the problem.
Tolerance for the LDU preconditioning
Precision of the preconditioner.
Default value: 1.0e-7
Print messages of the convergence evolution
Flag indicating to verbosity level of the iterative process. Set to “Yes” to prompt the evolution of the iteration process during the solving.
Default value: “No”
PETSc
PETSc is a library of parallel and distribute iterative solvers. A pre-selection of pairs of solver/preconditioner was made depending on the dimension and type of problem. The process number is defined in Flux Supervisor, see parallel computing for details.
Options
No options are available for the current version
GMRes
GMRes is an iterative solver which uses the restart generalized minimum residual for the solving and the incomplete factorization with ILUT for the preconditioning.
Options
Precision for GMRes
Maximum number of iterations for the GMRes
  • A fixed value N
Tolerance for the ILUT preconditioning
Coefficient for the level of fill for the ILUT preconditioning
Filling factor of the ILUT preconditioner.
Default value: 6.0
Dimension of the Krylov space
Number of vectors to store in order to build Krylov space.
Default value: 120
Default value: “No”
BiCGStab
BiCGStab is an iterative solver which uses the stabilized conjugate bi-gradient for the solving and the incomplete Choleski factorization of LDLT for the preconditioning. In steady State AC, BiCGStab uses incomplete factorization LDU for the preconditioning
Options
Precision for the BiCGStab
Maximum number of iterations for BiCGStab
  • A fixed value N
Default value: “No”
SuperLU
SuperLU is a direct method which uses the Gaussian elimination algorithm.
Options
Column reordering algorithm
Specifies how to permute the columns of the matrix for sparsity preservation. The reordering methods are:
  • Minimum degree on AT + A, minimum degree ordering on the structure of AT + A
  • Minimum degree on AT * A, minimum degree ordering on the structure of AT * A;
  • COLAMD, approximates minimum degree column ordering;
  • Dissection (2D) [Automatic in 2D], use METIS for the reordering;
  • Dissection (3D) [Automatic in 3D], use METIS for the reordering;
Default value: “Automatically specified reordering method”
Partial row pivoting
Set the row pivoting method. Two choices are available:
  • 0.0 to disable the pivoting;
  • ]0.0, 1.0[ to use the relaxed partial pivoting;
  • 1.0 to use the classical pivoting method.
Default value: 0.0
Iterative refinement
Specifies whether to perform iterative refinement, and in what precision to compute the residual.
Default value: “Without”
Symmetric mode
Specifies whether to use the symmetric mode. Symmetric mode gives preference to diagonal pivots and uses an (AT + A)-based column permutation algorithm.
Pivot growth computation
Specifies whether to compute the reciprocal pivot growth.
Condition number computation
Specifies whether to compute the reciprocal condition number.
Mumps
Mumps is a direct solver, based on a multi frontal approach.
Mumps (Local) is a mono-process, but multithread solver. There is only one process while number of threads is fixed by cores number choose by the user from the Flux supervisor.
Mumps (Distributed) is a multi-process and multithread solver. Process and thread numbers are defined in Flux Supervisor, see parallel computing for details.
Options
Verbosity level
Set the level of verbosity during the solving process. Four levels are available to decide what information will be prompted:
  • 1- Only errors messages
  • 2- Errors, warnings and main statistics
  • 3- Errors, warnings and terse diagnostics
  • 4- Errors, warnings and information on input and output parameters
Default value: “1- Only errors messages”
Using disk memory
Set the options regarding disk usage. Four options are available:
  • No, do not use the disk memory
  • Automatic – Switch over to Out-of-core depending on the matrix size
  • Yes – Default temporary directory
  • Yes – Choice of the temporary directory
Default value: “No”
Reordering method
Set the reordering method to use. Five methods can be used:
  • METIS
  • AMD – Approximate Minimum Degree
  • QAMD – AMD with quasi-dense rows detection
  • PORD
  • AMF
Default value: “Automatic – Choice in Mumps”
Memory limitation (RAM)
Set the memory limitation. It allows the user to limit the memory Mumps can use (in MB).
Default value: Unlimited
MPI Options
Only for MUMPS (Distributed). Set to define MPI Options. To enable MPI computations, the MPI number can be specified with the Thread number.
Default value: “No"
