Import Remote Loads from CSV
Apply/create load cases with remote Forces/Moments from an external comma separated values (CSV) file.
Loads are mapped from the remote point to the closest part face or to specific faces by defining the spatial coordinates. All loads and locations are specified in the global coordinate system. You can specify multiple load cases in each .csv file, although only one may be applied at a time.
  1. On the Project Tree, open the Analysis Workbench.
  2. Depending on the type of analysis, select the following:
    • For Structural analysis, select > Imported remote load.
    • For Multi-loadcases analysis, select (Load cases) > Imported remote load
  3. In the dialog, click the Import from CSV button.
  4. Browse to the desired CSV file in the File explorer.
  5. Click Open.
  6. In the dialog, if more than one load case is present in the .csv file, select the load case to apply in the drop-down menu.
    Note: For multi-loadcases, when more than one load case is specified in the .csv file, multiple load cases are automatically created on import.
  7. Optional: If desired, edit loads.
    1. Select a row in the dialog and click Edit load.
      Tip: You can also double-click on a row to edit. Both methods will display a remote load dialog.
    2. In the remote load dialog, edit desired values (remote load location, load values, and application faces/spots).
    3. Click OK.
  8. In Imported remote loads, specify Coordinates, Force, and Moment units.
  9. Click OK.
Imported Remote Load CSV File Format
CSV file format for importing remote loads.
CSV file format fields
The CSV file contains one header row and one or more additional data rows. Data values are as follows:
  • X, Y and Z – Numeric values. Spatial location of the remote load.
  • Fx, Fy and Fz – Numeric values. Force component values in X, Y and Z directions.
  • Mx, My and Mz – Numeric values. Moment component values in X, Y and Z directions.
  • Load case – (optional) String value. Only required if multiple load cases are present.
  • X1, Y1 and Z1 – (optional) Numeric values. Spatial location of a point on the 1st face to be mapped. Only required if mapping to specific faces.
  • T1 – (optional) Yes/No. No entry is treated as ‘No’. Enables tangency option to add faces tangent to the face mapped using X1, Y1, Z1.
  • X2, Y2 and Z2 – (optional) Numeric values. Spatial location of a point on the 2nd to be mapped. Only required if mapping to specific faces.
  • T2 – (optional) Yes/No. No entry is treated as ‘No’. Enables tangency option to add faces tangent to the face mapped using X2, Y2, Z2.
Example CSV file
X,Y,Z,Fx,Fy,Fz,Mx,My,Mz, X1,Y1,Z1,T1,X2,Y2,Z2,T2 ,Load case
50,50,50,100,0,0,0,0,0,10,20,20,Yes,70,70,70,No,load_1
50,10,50,0,100,0,0,0,0,,,,,,,,,load_2
