Define Shield Properties - Legacy
This option allows you to define the shield properties by either a manual definition in the .pre file or by loading from file.
Parameters:
- Use legacy shields definitions
- Unselect this option to define a layered shield using shield definitions from an SD card.
- Define in *.pre file
- Define the frequency dependent shield parameters based on measured transfer impedance and admittance data in the .pre file.
- Load from file
- The file format used when importing measured cable data from file is described in Load Measured Cable Data From File.
- Frequency
- The frequency at which the transfer impedance and admittance are specified in the .pre file below.
- Zt Magnitude - Magnitude of transfer impedance
- The magnitude of the transfer impedance defined in the .pre file.
- Zt Phase - Phase of transfer impedance
- The phase of the transfer impedance defined in the .pre file.
- Yt Magnitude - Magnitude of transfer admittance
- The magnitude of the transfer admittance defined in the .pre file.
- Yt Phase - Phase of transfer admittance
- The phase of the transfer admittance defined in the .pre file.
- Metallic material
- PEC
- Select this option to set the shield of the filaments to PEC.
- Material label
- The label of the metallic material (as defined in the DI card) to be used for the shield.
- Coating
- Material label for coating
- The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
- Thickness of layer for coating
- Define the thickness of the dielectric coating.
- Shield thickness
- The thickness of the shield.
<?xml version="1.0" encoding="UTF-8"?> <cableDB creator="name" date="2011-07-30" version="1.0"> <shielding name="shielding1"> <dataPoint freq="100e6" trans_imp_abs="5" trans_imp_phase="0" trans_adm_abs="0" trans_adm_phase="2"/> <dataPoint freq="300e6" trans_imp_abs="6" trans_imp_phase="2" trans_adm_abs="4" trans_adm_phase="1"/> <dataPoint freq="500e6" trans_imp_abs="4" trans_imp_phase="3" trans_adm_abs="3" trans_adm_phase="2"/> <dataPoint freq="700e6" trans_imp_abs="1" trans_imp_phase="5" trans_adm_abs="2" trans_adm_phase="5"/> </shielding> </cableDB>
