Double Cable Shield
This option defines a cable shield with two layers.
Figure 1. The SH - Cable shield dialog, set to 2 layers.
Parameters:
- Shield label
- The name of the shield.
- Number of layers
- The total number of layers.
- Material label
- The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
- Thickness of layer for coating
- Define the thickness of the dielectric coating.
- Shield definition label (Zt + Zs)
- The shield layer (SD card) that is to be used for the impedance part of layer 1.
- Shield definition label (Yt)
- The shield layer (SD card) that is to be used for the admittance part of layer 1.
- Gap between layer 1 and 2 (m)
- Air (free space) gap between layer 1 and layer 2 in meters.
- The shield layer (SD card) to be used for the impedance part of layer 2.
- The shield layer (SD card) to be used for the admittance part of layer 2.
