Modal Damping Creation Tutorial
Create Modal Damping
  1. Select CRIT from the Damping Type drop down list.
  2. Click button twice to insert two rows in the damping table.
    Note: You can create the complete damping table using this method.
  3. Enter the values in the X and Y columns as shown below
    X Y
    0.0 0.04
    200 0.04
  4. Click Add.
    The damping table will be created and listed in the adjacent table.
  5. Click the radio button corresponding to the required damping table to activate it.
  6. Click Next to proceed to the next step in the process.
    Note: You should create and activate at least one damping table in this panel before moving to the next step.
