Transient Load Creation Tutorial
Create TLoads
  1. Click the required table from the TABLED1 drop down list.
    The drop down list shows all the loads created in the Load Creation Tutorial step.
  2. Click the required unit load from the DAREA/SPCD drop down list.
    The drop down list shows all the tables created in the Constraint Creation Tutorial step.
  3. Click Add.
    The adjacent table shows the newly created transient load collector.
    Figure 3.
  4. Repeate the above steps to create transient loads for below selection
    • MTRAN_TABLED1_2 and MTRAN_SPCD_EnforcedDisp_528173_Y
    • MTRAN_TABLED1_3 and MTRAN_SPCD_EnforcedDisp_528173_Z
  5. Check the boxes under Select column and click Next to proceed to the next step in the process.
    Note: You should create at least one load collector in this panel before moving to the next step.
