Output Request Creation
In this step, you can define output types and node/node sets for obtaining nodal loadcase outputs. The panel is shown below.
The outputs panel supports three output types:
  1. Displacement
  2. Velocity
  3. Nodal Force
Select Response Type
  1. Click the required output response type from the Response Type drop down list. The available options are:
    • Displacement
    • Velocity
    • NodalForce
  2. Click the required entity selection method from the Entity Selection option. The choices are:
    • Nodes
    • Node set
Define Output Based on Nodes
  1. Click Nodes from the Entity selection drop down menu.
    A node selection panel will be displayed.
  2. Select the required nodes using any of the node selection options available on the panel.
  3. Click proceed.
Define Output Based on Node Sets
  1. Click Node set from the Entity selection drop down menu.
    A node set selection panel will be displayed.
  2. Select the required node sets from the panel by selecting the appropriate check box.
  3. Click select.
  4. Click proceed.
  5. Click Create.
    A new output will be added and the same is listed in the adjacent table.
Auto Create Outputs
    1. Displacement
    2. Velocity
    3. Nodal Force
  2. Click Auto Add.
    A set that contains all the nodes belonging to the E-Lines of the model.
  3. Click Next to proceed to the next step in the process.
    Note: You need to create and activate at least one output in this panel before moving to the next step.
