Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using
best-in-class solver technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Below are the steps to perform Combined Loading operations
To verify the combined effects
Select the dynamic loadcase from the Loading Type 1
list.
This will disable Affects Gap check
box.
Keep the default Scale Factor value.
Select All line from E-Line(s)
Selection list and click Summary
Analysis.
This will execute and run the detailed analysis for the combine loading
effect. You can observe the summary page for the complete simulation.Figure 1.
From the summary page, it can be observed that the ELine
19488009 has the maximum relative displacement of value
2.81 mm under combined loading effect. You will run the
further evaluation on this line.
Now select 19488009 from E-Line(s)
Selection list and click Full
Analysis
This will plot the results for the selected line.Figure 2.
To verify thermal effect on gap
With the Affects
Gap box checked, you will verify the effect of thermal expansion
on the gaps between the parts while applying the vibration load to the system
analyzed
Check the Affects Gap box against Loading
Type 2.
Select 19488009 from E-Line(s)
Analysis
This will run the detailed analysis for the selected line and plot the
results. You can verify the summary and results pages for the thermal effect on
the gap.
Summary for thermal effect on gaps -Figure 3.
Detailed results plot for the selected line -Figure 4.
From the plots, you can observe the following -
There is a change in the gap between the components due to
thermal expansions. Curves labeled
NewGap_Nominal_LC2_R1_Z and
NewGap_Tolerance_LC2_R1_Z show the change
in gap values.
It can also be observed that the relative displacement has
reduced from 2.81 mm to 2.73
mm. This analysis states that the thermal effects
has reduced the relative displacement, in turn leading to
reduced rattle noise.
